CubeCell Dev Board V2: Battery and Solar cell
Can I assume that with the new version (CubeCell Dev Board V2) there is no longer the need to add a diode to Vs?
Furthermore, even with the older version the Diode is not needed if I never connect USB cable together with solar panel right? (for example I use only Lipo battery and recharge them with solar panel).
Thanks in advance.
