I have an arduino sketch that reads a 1-wire temperature sensor, and sends it via Lora (peer-to-peer).
I’d like to combine it with deep sleep, retrieving and sending data every 15min. The sleep example sketches provided by Heltec work great, but when I combine them with my own sketch, the system never sleeps (I see this via the serial monitor, my printfs keep coming)
I’m breaking my head on how to solve this… (I’m a noob)… Your help is highly appreciated.
extract code:
void onSleep()
Serial.printf("Going into lowpower mode, %d ms later wake up.\r\n",timetillwakeup);
lowpower=1;
//timetillwakeup ms later wake up;
TimerSetValue( &wakeUp, timetillwakeup );
TimerStart( &wakeUp );
void onWakeUp()
Serial.printf("Woke up, %d ms later into lowpower mode.\r\n",timetillsleep);
lowpower=0;
TimerStart( &sleep );
boardInitMcu( );
txNumber=0;
rssi=0;
Radio.Init( &RadioEvents );
//init 18b20 1-wire
pinMode(Vext,OUTPUT);
digitalWrite(Vext,LOW);
delay(500);
//setup for sleep
Radio.Sleep( );
TimerInit( &sleep, onSleep );
onSleep();
if(lowpower){
lowPowerHandler();
byte i;
byte present = 0;
byte type_s;
byte data[12];
byte addr[8];
float celsius, fahrenheit;
if ( !ds.search(addr)) {
Serial.println("No more addresses.");
Serial.println();
ds.reset_search();
delay(250);
return;
Serial.print("ROM =");
for( i = 0; i < 8; i++) {
Serial.write(' ');
Serial.print(addr[i], HEX);
if (OneWire::crc8(addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return;
Serial.println();
// the first ROM byte indicates which chip
switch (addr[0]) {
case 0x10:
Serial.println(" Chip = DS18S20"); // or old DS1820
type_s = 1;
case 0x28:
Serial.println(" Chip = DS18B20");
type_s = 0;
case 0x22:
Serial.println(" Chip = DS1822");
type_s = 0;
Serial.println("Device is not a DS18x20 family device.");
return;
ds.reset();
ds.select(addr);
ds.write(0x44, 1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print(" Data = ");
Serial.print(present, HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print(OneWire::crc8(data, 8), HEX);
Serial.println();
// Convert the data to actual temperature
// because the result is a 16 bit signed integer, it should
// be stored to an "int16_t" type, which is always 16 bits
// even when compiled on a 32 bit processor.
int16_t raw = (data[1] << 8) | data[0];
if (type_s) {
raw = raw << 3; // 9 bit resolution default
if (data[7] == 0x10) {
// "count remain" gives full 12 bit resolution
raw = (raw & 0xFFF0) + 12 - data[6];
} else {
byte cfg = (data[4] & 0x60);
// at lower res, the low bits are undefined, so let's zero them
if (cfg == 0x00) raw = raw & ~7; // 9 bit resolution, 93.75 ms
else if (cfg == 0x20) raw = raw & ~3; // 10 bit res, 187.5 ms
else if (cfg == 0x40) raw = raw & ~1; // 11 bit res, 375 ms
//// default is 12 bit resolution, 750 ms conversion time
celsius = (float)raw / 16.0;
Serial.print(" Temperature = ");
Serial.print(celsius);
Serial.print(" Celsius, ");
//LORA
txNumber += 0.01;
char str_temp[6];
/* 4 is mininum width, 2 is precision; float value is copied onto str_temp*/
dtostrf(celsius, 4, 2, str_temp);
unsigned int n;
int checksum = 0;
char checksum_s [4];
for (n=0; n<sizeof(str_temp);n++){
checksum += str_temp[n];
checksum = checksum % 256;
Serial.print("\nChecksum: ");
Serial.print(checksum);
sprintf(checksum_s,"%u",checksum);
sprintf(txpacket,"%02x",tx_id);
strcat(txpacket,";");
strcat(txpacket, str_temp);
strcat(txpacket,checksum_s);
Serial.print("\ntxpacket: ");
Serial.print(txpacket);
checksum = 0;
