Trying to connect a DAllas Temp Sensor and fail to compile the CubeCell Example -
Examples - CubeCell Third Party - DallasTemperature - Simple.
thx a lot for all help!
Arduino: 1.8.13 (Mac OS X), Board: "CubeCell-Board(HTCC-AB01), REGION_EU868, CLASS_A, OTAA, ON, CONFIRMED, OFF, ON, ACTIVE, None"
WARNING: library OneWire claims to run on ASR650x-Arduino architecture(s) and may be incompatible with your current board which runs on CubeCell architecture(s).
/Users/i511648/Library/Arduino15/packages/CubeCell/tools/gcc-arm-none-eabi/8-2019-q3/bin/../lib/gcc/arm-none-eabi/8.3.1/../../../../arm-none-eabi/bin/ld: libraries/DallasTemperature/DallasTemperature.cpp.o: in function `DallasTemperature::blockTillConversionComplete(unsigned char)':
/Users/i511648/Documents/Arduino/libraries/DallasTemperature/DallasTemperature.cpp:446: undefined reference to `yield()'
collect2: error: ld returned 1 exit status
exit status 1
Error compiling for board CubeCell-Board(HTCC-AB01).
Complete code is this:
// Include the libraries we need
#include <OneWire.h>
#include <DallasTemperature.h>
#include "Arduino.h"
// Data wire is plugged into GPIO5 on the CubeCell
#define ONE_WIRE_BUS GPIO5
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
The setup function. We only start the sensors here
void setup(void)
// Vext ON
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
delay(10);
// start serial port
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
Main function, get and show the temperature
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures(); // Send the command to get temperatures
Serial.println("DONE");
// After we got the temperatures, we can print them here.
// We use the function ByIndex, and as an example get the temperature from the first sensor only.
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(sensors.getTempCByIndex(0));
delay(500);
