I’m trying to make a ping pong beetwen ESP32 V2 and CubeCell Module, I’m having problems with the CubeCell as a sender, I´m getting BoardInitMcu() was not declare in the scope and RGB_ON was not declare in the scope. What the problem could be?
here is the code:
#include “LoRaWan_APP.h”
#include “Arduino.h”
- RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
int16_t txnumber;
int16_t RSSI,rxSize;
BoardInitMcu( );
txnumber=0;
RSSI=0;
Radio.Init( &RadioEvents );
txnumber++;
sprintf(txpacket,"%s","how long can hello tx be");
sprintf(txpacket+strlen(txpacket),"%d",txnumber);
RGB_ON(COLOR_SEND,0);
Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
