CubeCell capsule do not find MPU9250
I just received my Capsule with a MPU9250 sensor. I uploaded the right firmware and I’m facing an issue: no sensor found.
Am I missing something?
Thanks in advance
need some more info to help you.
which firmware have you flashed?
Please post the output of the serial terminal after pressing the reset button.
same results with BMP280
the BMP280 is not supported not supported anymore since version 3.0.9.
have you flashed the Capsule version or the board version?
I flashed using capsule version
