I was just wondering if battery voltage monitoring is supported for the capsule? When I call the getBatteryVoltage function I get ~0.2V even though there is enough battery voltage for the board to function. For the CubeCell Board-Plus I know the ADC is used for battery monitoring, is this also true for the capsule? Thanks!
CubeCell Capsule Battery Monitoring
hi,
The anwser is Yes!
Thanks Jason.
Why do I see ~0V for the battery voltage? Do I need to solder something to hook this up? Looking at the code, it is running the following:
pinMode(VBAT_ADC_CTL,OUTPUT);
digitalWrite(VBAT_ADC_CTL,LOW);
uint16_t volt=analogRead(ADC)*2;
* Board, BoardPlus, Capsule, GPS and HalfAA variants
* have external 10K VDD pullup resistor
* connected to GPIO7 (USER_KEY / VBAT_ADC_CTL) pin
pinMode(VBAT_ADC_CTL, INPUT);
hi,
You can use this code:
I have tested this code and it work well. Please refer my serial print log:
Hi Jason,
When I run this example I get the following:
12
12
12
12
12
12
12
12
12
12
12
Is there a solder joint I need to make on the Capsule PCB to monitor the battery, or is the unit faulty?
Many thanks.
hi,
I guess maybe the capsule is bad.
Could you check this location:
Or you can directly test the ADC with the chip:
