When I’m trying to execute examples on the CubeCell board, I get the error:
Initialising bootloader.
Unhandled error: Timed out waiting for Bootloader response.
I have read the Most Common Problems page but I don’t understand if this is addressing the problem I am having. Do I need to “Access Bootloader Mode” in order to be able to “Initialize” it? It says that if I do it, I “can’t Download Firmware anymore”. What does this mean? I’m guessing it is not about not being able to upload sketches anymore.
But more importantly: Why should I need to short two pins in order to be able to upload sketches? I have worked with the WiFi Esp32 V2 boards so far without problems.
Thank you for your help.
Cristian
