CubeCell-Board Plus(HTCC-AB02)stop working or jam just after few minutes
I am using two HTCC-AB02 board, one as master and one as slave which is connected to DHT11 sensor. The master board will call slave to send respective temperature and humidity data to the master board. At first, both are functioning well. However, just after a few minutes, they stop working. Below is my coding for both master and slave.
Master:
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include <Wire.h>
#include “HT_SH1107Wire.h”
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define RF_FREQUENCY 923000000 // Hz
#define TX_OUTPUT_POWER 5 // dBm
#define LORA_BANDWIDTH 0 // [0: 125 kHz, 1: 250 kHz, 2: 500 kHz, 3: Reserved]
#define LORA_CODINGRATE 1 // [1: 4/5, 2: 4/6, 3: 4/7, 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 80 // Define the payload size here
unsigned long lastReadingTime = 0;
const unsigned long interval1 = 10000L;
const unsigned long interval2 = 5000L;
int i = 1;
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
void OnTxTimeout( void );
bool sleepMode = false;
int16_t Rssi, rxSize;
delay(50);
Rssi = 0;
Radio.Init( &RadioEvents );
void callTemp() {
sprintf(txpacket, “%s”, “Temp”);
turnOnRGB(COLOR_SEND, 0);
Serial.printf(txpacket, strlen(txpacket));
Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
lowPowerHandler();
delay(400);
turnOnRGB (1, 1);
void callHum() {
sprintf(txpacket, “%s”, “Hum”);
lowPowerHandler();
delay(400);
turnOnRGB (1, 1);
if (millis() - lastReadingTime > interval1) {
i = 0;
lastReadingTime = millis();
callTemp();
if (millis() - lastReadingTime > interval2 && i == 0) {
i = 1;
callHum();
else {
turnOnRGB (1, 1);
Radio.Rx( 0 );
// lowPowerHandler();
Radio.IrqProcess( );
delay(400);
Rssi = rssi;
rxSize = size;
rxpacket[size] = ‘\0’;
turnOnRGB(COLOR_RECEIVED, 0);
delay(100);
Radio.Sleep( );
Serial.println();
Serial.printf(rxpacket);
delay(400);
Radio.Sleep( );
Serial.println(“TX Timeout…”);
Slave:
#include <Wire.h>
#ifndef LoraWan_RGB
//SH1107Wire displayz(0x3c, 500000, SDA, SCL , GEOMETRY_128_64, GPIO10); // addr, freq, sda, scl, resolution, rst
const unsigned long interval = 10000L;
//void OnTxDone( void );
#include <DHT.h>
#define DHTPIN GPIO5
#define DHTTYPE DHT11
char temp[10];
char humid[10];
float h, t;
DHT dht(DHTPIN, DHTTYPE);
delay(50);
dht.begin();
delay(3000);
Rssi = 0;
byte getdata() {
h = dht.readHumidity();
delay(10);
t = dht.readTemperature();
delay(10);
Serial.print("Humid: ");
Serial.println(h);
Serial.print("Temp: ");
Serial.println(t);
void sending_temp_data() {
dtostrf(t, 4, 1, temp);
sprintf(txpacket , “%s”, temp );
sprintf(txpacket + strlen(txpacket), “%s”, “°C\n” );
lowPowerHandler();
delay(500);
turnOnRGB (1, 1);
void sending_hum_data() {
dtostrf(h, 4, 1, humid);
sprintf(txpacket, “%s”, humid);
sprintf(txpacket + strlen(txpacket), “%s”, “%\n”);
lowPowerHandler();
delay(500);
turnOnRGB (1, 1);
turnOnRGB (1, 1);
if (millis() - lastReadingTime > interval) {
getdata();
else {
turnOnRGB (1, 1);
Radio.Rx( 0 );
Rssi = rssi;
rxSize = size;
delay(500);
Radio.Sleep( );
String call(rxpacket);
if (call == “Temp”) {
sending_temp_data();
if (call == “Hum”) {
sending_hum_data();
Radio.Sleep( );
It looks/sounds to me like one of your nodes, probably the slave, is going to sleep and not waking up.
A few strategically placed ‘print’ statements might help work out where things are stalling. Removing all references to the lowPowerHandler(), and sleeping of the radio, might also eliminate those as potential causes. You can then add the sleep/low power stuff back in where it makes sense and see what happens.
After removing the lowPowerHandler() and sleeping, I think the problem is solved. Both can run without stopping for more than 12hours so far.
Thanks a lot.
Good morning, I was having similar problem of the board freezing after an undefined period of time, mostly related to the GPS (not that I know anything!)- so I’ve now added a watchdog into the which is disabled in lowpower mode.
They have example scripts.
CySysWdtEnable(); //enable the WDT
CySysWdtDisable(); //disable the WDT before going to sleep
etc…
Cheers, James
