Hi Everyone,
I am evaluating the CubeCell Board AB01 for a project (only LoRa, not LoraWAN) because it is really a cool hardware (also the best low power usage I have seen so far).
I am trying to integrate the board with the RadioLib library (https://github.com/jgromes/RadioLib) and having some issues.
First issue is with pinMode() macro defined in Arduino.h. It is conflicting with the RadioLib override of the same function. I commented out the pinMode macro in the Arduino.h, it fixes the issue, but I want to make sure it is safe to do that and won’t break anything else.
Second issue is I am trying to find the function/macro to be used to convert digital pin number to interrupt pin number. On Arduino boards it is typically defined as digitalPinToInterrupt(). But that doesn’t seem to be defined. What is the equivalent for ASR650x?
Thanks for the help,
A.
