Cubecell + Bluetooth
Hi, anyone have some experience using Bluetooth with cubecell.
What chipset do you use and what library?
What was the result?
thanks!
@jasonXu or @Supporter can you help with this friends ?
I want to use SIM800C module and use Bluetooth library.
CubeCell series don’t have Bluetooth function onboard.
If we update an example for ESP32 + LoRa series, with the function of “Bluetooth – LoRaWAN”, is that will make sense to you?
Hi. Yes totally, I also want to use ESP32 as wifi module.
Will be great use for both bluetooth and wifi.
