Hello I have being triying to run my CubeCell ASR650 but it’s never works, I have install everything perfectly but I can’t compile any example.
I try for example the LoRaSender example and I got this problem and I can’t find the solution.
Problem:
WARNING: library LoRa claims to run on ASR650x-Arduino architecture(s) and may be incompatible with your current board which runs on CubeCell architecture(s).
WARNING: library RGB claims to run on ASR650x-Arduino architecture(s) and may be incompatible with your current board which runs on CubeCell architecture(s).
exec: “C:\Users\Curro”: file does not exist
Error compiling for board CubeCell-Board.
Here is the code: PLEASE HELP!
/* Heltec Automation Ping Pong communication test example
- Function:
- Send data from a CubeCell device over hardware
 - this project also realess in GitHub:
 - https://github.com/HelTecAutomation/ASR650x-Arduino
#include “LoRaWan_APP.h”
#include “Arduino.h”
 - RGB red means sending;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
#define LORA_BANDWIDTH                              0         // [0: 125 kHz,
//  1: 250 kHz,
//  2: 500 kHz,
//  3: Reserved]
#define LORA_SPREADING_FACTOR                       7         // [SF7…SF12]
#define LORA_CODINGRATE                             1         // [1: 4/5,
//  2: 4/6,
//  3: 4/7,
//  4: 4/8]
#define LORA_PREAMBLE_LENGTH                        8         // Same for Tx and Rx
#define RX_TIMEOUT_VALUE                            1000
#define BUFFER_SIZE                                 30 // Define the payload size here
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
int16_t txNumber;
int16_t rssi,rxSize;
boardInitMcu( );
txNumber=0;
rssi=0;
Radio.Init( &RadioEvents );
txNumber++;
sprintf(txpacket,"%s",“Hello world number”);  //start a package
sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
turnOnRGB(COLOR_SEND,0); //change rgb color
