I believe the best low power performance on the AB01 dev board comes when Vdd is directly powered, with the data sheet saying Vdd should be from 3.0 to 3.3 volts. I have been doing that using a battery which starts slightly above 3.3v. This works very well and I’ve been able to see 3.5uA sleeps using a meter, and then executed two field trials of several months length. My time of service on a single battery is really only limited by the message duty cycle I choose. Ultimately though the battery drops significantly below 3.0v and things stop working (see below).
The plan had been to use the ADC to monitor battery voltage, after removing BR01, and using Vext to keep from bleeding electrons through a voltage divider. That circuit works fine and is able to take meaningful readings using the ADC on a bench setup. Unfortunately, it looks like Vref changes as Vdd drops? That’s just a guess. It behaves like the Vref change is directly in proportion to the Vdd change, and thus the ADC reports nearly the same value no matter what my battery voltage is. I’ve recently used a pair of adjustable power supplies to check this and can actually watch my readings go up as I dial Vdd down if I keep the ADC pin voltage steady. I’ll probably try to take some data a bit later to see if it’s linear, and try another AB01 board. It’s a difficult test setup because right now I have to use LoRa messaging to watch the board behavior when powered through Vdd. Note that if the behavior is not linear then we’re good and it’s just a matter of mapping the behavior. If Vref and Vdd are directly tied then it pretty much makes the ADC useless for this purpose.
I am using the “CubeCell Development Framework” version 0.0.5 updated a few days ago through the Arduino IDE. Would it be possible for someone else to confirm the ADC behavior? At this point I believe I have to abandon the direct Vdd power or get an external ADC (or maybe there’s a software patch?) I will be experimenting this week with an I2C ADC, but it would be sort of sad to not use the one supplied on the chip. Is there any chance the ASR6502 is different, or there’s a code change not in the 0.0.5 version?
