I have one CubeCell AB01 out of a batch of 5 which shows a weird failure.
everything works fine … until I do use the LoRaWAN example.
with LoRaWAN it gets stuck in the LoRaWan INIT call … and nothing else happens.
if I use the other devices of the same batch … no problem.
any idea on how to debug this issue? the Arduino code is the same for all of them…
thanks
