I recently purchased a Cube Cell HTCC-AB02S and I want to use it in my local LoRa network (no LoraWan). I’m using another board (heltec_wifi_lora_32_V2) to receive simple packets and it works with other heltec lora boards of the same type. It will not receive simple “ping pong” transmissions from the AB02S board. I am ready to return the board as “defective or unusable”.
Will the AB02S work with my simple LoRa network? If so, where can I get test code?
