Compile Error for LoRaWAN
Hi there,
I have a LoRaWAN Node w/ HTCC-AB01 board working.
Now I tried to compile a change program and get a compile error.
Were there any changes?
Arduino: 1.8.13 (Windows 10), Board: “CubeCell-Board(HTCC-AB01), REGION_EU868, CLASS_A, OTAA, ON, UNCONFIRMED, OFF, ON, DEACTIVE, None”
WARNING: library LoRa claims to run on ASR650x-Arduino architecture(s) and may be incompatible with your current board which runs on CubeCell architecture(s).
libraries\LoRa\LoRaWan_APP.cpp.o: In function `getBatteryVoltage’:
C:\Users\install\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.0.0\libraries\LoRa\src/LoRaWan_APP.cpp:246: multiple definition of `getBatteryVoltage’
sketch\LoRaWan_APP.cpp.o:sketch/LoRaWan_APP.cpp:248: first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `BoardGetBatteryLevel’:
LoRaWan_APP.cpp:(.text.BoardGetBatteryLevel+0x0): multiple definition of `BoardGetBatteryLevel’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text.BoardGetBatteryLevel+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `lwan_dev_params_update’:
LoRaWan_APP.cpp:(.text.lwan_dev_params_update+0x0): multiple definition of `lwan_dev_params_update’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text.lwan_dev_params_update+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `SendFrame’:
LoRaWan_APP.cpp:(.text.SendFrame+0x0): multiple definition of `SendFrame’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text.SendFrame+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::init(eDeviceClass, eLoRaMacRegion_t)’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4initE12eDeviceClass16eLoRaMacRegion_t+0x0): multiple definition of `LoRaWanClass::init(eDeviceClass, eLoRaMacRegion_t)’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4initE12eDeviceClass16eLoRaMacRegion_t+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::join()’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4joinEv+0x0): multiple definition of `LoRaWanClass::join()’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4joinEv+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::send()’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4sendEv+0x0): multiple definition of `LoRaWanClass::send()’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass4sendEv+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::cycle(unsigned long)’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass5cycleEm+0x0): multiple definition of `LoRaWanClass::cycle(unsigned long)’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass5cycleEm+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::sleep()’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass5sleepEv+0x0): multiple definition of `LoRaWanClass::sleep()’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass5sleepEv+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o: In function `LoRaWanClass::ifskipjoin()’:
LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass10ifskipjoinEv+0x0): multiple definition of `LoRaWanClass::ifskipjoin()’
sketch\LoRaWan_APP.cpp.o:LoRaWan_APP.cpp:(.text._ZN12LoRaWanClass10ifskipjoinEv+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0xb0): multiple definition of `LoRaWAN’
sketch\LoRaWan_APP.cpp.o:(.bss+0xb0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0xa8): multiple definition of `LoRaMacCallback’
sketch\LoRaWan_APP.cpp.o:(.bss+0xa8): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0x98): multiple definition of `LoRaMacPrimitive’
sketch\LoRaWan_APP.cpp.o:(.bss+0x98): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0x1): multiple definition of `deviceState’
sketch\LoRaWan_APP.cpp.o:(.bss+0x1): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.data+0x2): multiple definition of `modeLoraWan’
sketch\LoRaWan_APP.cpp.o:(.data+0x2): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0x0): multiple definition of `passthroughMode’
sketch\LoRaWan_APP.cpp.o:(.bss+0x0): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0xb4): multiple definition of `txDutyCycleTime’
sketch\LoRaWan_APP.cpp.o:(.bss+0xb4): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.bss+0x18): multiple definition of `appData’
sketch\LoRaWan_APP.cpp.o:(.bss+0x18): first defined here
libraries\LoRa\LoRaWan_APP.cpp.o:(.data+0x1): multiple definition of `appDataSize’
sketch\LoRaWan_APP.cpp.o:(.data+0x1): first defined here
sketch\LoRaWan_APP.cpp.o: In function `lwan_dev_params_update’:
sketch/LoRaWan_APP.cpp:453: undefined reference to `userChannelsMask’
C:\Users\install\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.0.0/cores/asr650x/projects/CubeCellLib.a(AT_Command.o): In function `getDevParam’:
D:\lib/AT_Command.c:1241: undefined reference to `userChannelsMask’
C:\Users\install\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.0.0/cores/asr650x/projects/CubeCellLib.a(AT_Command.o): In function `onUartEvent’:
D:\lib/AT_Command.c:1082: undefined reference to `userChannelsMask’
C:\Users\install\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.0.0/cores/asr650x/projects/CubeCellLib.a(AT_Command.o): In function `printDevParam’:
D:\lib/AT_Command.c:1393: undefined reference to `userChannelsMask’
exit status 1
Error compiling for board CubeCell-Board(HTCC-AB01).
Hi
why do you have a LoRaWan_APP.cpp file in your sketch directory?
I did believe I have to include it. Am I wrong?
I deleted the LoRaWan_APP.cpp and LoRaWan_APP.h from my sketch folder. But, …
#include <LoRaWan_APP.h>
#include “Arduino.h”
C:\Users\install\AppData\Local\Arduino15\packages\CubeCell\hardware\CubeCell\1.0.0\libraries\LoRa\src/LoRaWan_APP.cpp:440: undefined reference to `userChannelsMask’
exit status 1
what ist that file: D:\lib/AT_Command.c
it seams that you have mixed your librarys in different locations
My problem was quite simple. I thought to have a library mismatch. After changing the computer and getting the same error. I looked in the source.
The line
was missing. I have no idea, if it was deleted or missing from the beginning.
The old source was running over months.
But now it works. Thanks.
