I have tried to compile the factory test example for Wireless stick lite v3 and I’m getting the following error:
I am running Arduino IDE 2.01 on Windows 11.
Any workaround until there is an official fix for this ?
Thanks in advance, Wolfgang
I tried to do some debugging. It looks like the compiler pulls the definitions for the old WSL(V1) definitions where there was no RADIO_BUSY signal on a dedicated pin.
I suspect that the config files need to be updated to the pins used with the new ESP32 chip.
SOLVED: I selected the wrong board in board manager
Which board did you choose for it to work ?
