Greetings,
Just a disclaimer I am a total newbie with this stuff, and trying to dive into it and learn how to use it. I bought a LoRa 32 v3 module, Amazon listing
I bought this board because I wanted to have a general purpose dev board to do some projects on, and lean about LoRa.
I started it up on my computer and it ran the WIFI_LoRa_32 factory test code without attaching the antenna, everything seems to work fine (WIFI setup, WIFI scan, OLED) But since i only have one of these LoRa modules, I can’t test if the module is still working, I am worried that i cooked the LoRa module when i started it up without the antenna on. Short of buying more modules, Is there a way i can check if the LoRa module is still operational?
Thanks for your help!
