Hi ho,
I try to send more then two digits with the prepareTxFrame, but I find no way to do it…
CODE:---------------------------------------------------------------------------------------------------------
// packet_version and Selftest:
//First Digit is the Type, second the Selftest-Status 0-F
int PACKET_VERSION = 0xAA;
// Battery-Power
int BATTERYSTATUS = 0x41;
int PM1 = 0xFF;
int PM25 = 0x10;
int PM4 = 0x00;
int PM5 = 0xC0;
int PM10 = 0xB0;
uint8_t prepareTxFrame( uint8_t port )
connectDHT();
appDataSize = 11; //AppDataSize max value is 64
appData[0] = PACKET_VERSION;
appData[1] = BATTERYSTATUS;
appData[2] = Temperature;
appData[3] = Humidity;
appData[4] = PM1;
appData[5] = PM25;
appData[6] = PM4;
appData[7] = PM5;
appData[8] = PM10;
appData[9] = Voc;
appData[10] = COtwo;
The output is everytime only the HEX-2digits Code… I am not able to add more. Do you have an idea?
The problem is that my values are bigger then 256 numbers
best regards
Tjark
