CC-AB01 Radio stops responding
Hi Everyone,
I’m seeing some interesting behavior from my CC-AB01 (V2s) devices. Basically the unit stops responding to LoRa messages but the board is still running (at least the light is on). This has been difficult to characterise as it seems pretty inconsistent and random. Sometimes it has issues a few mins after boot up, other times it runs fine for a while then stops. I’ve checked my power supply etc etc and all seems ok on that front. I did notice in my code that I was using Radio.Rx(RX_TIMEOUT_VALUE) where RX timeout val is 1000. However, I didnt explicitly handle the timeout.
Eg:
void setup()
Serial.begin(9600);
while (!Serial) ; // Wait for serial port to be available
// Initialize Radio with optimized parameters for HTCC-AB01
Radio.Init(&RadioEvents);
Radio.SetChannel(RF_FREQUENCY);
Radio.SetTxConfig(xxx);
Radio.SetRxConfig(xxx);
// Start receiving
Radio.Rx(RX_TIMEOUT_VALUE);
// Handle radio events
Radio.IrqProcess();
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr)
DoSomeStuff…
// Return to receive mode
void OnTxDone(void)
Serial.println(“TX done”);
// Return to receive mode after transmission
What would be the likely impact of not explicitly handling the RxTimeouts? Could the radio get into a funky state and stop responding?
I’ve added a timeout handler to my code:
void setup()
RadioEvents.RxTimeout = OnRxTimeout; // Add timeout handler
// … rest of existing setup code …
void OnRxTimeout(void)
Serial.println(“RX Timeout - restarting receive mode”);
Do you think adding the RX time out handler is likely to address the issue? My problem is I dont have the foggiest as to what else could be causing the issue. I’ve seen a few other posts suggesting a radio re-initialise etc but I’d like to avoid getting the board to do more work than it really needs to.
Suggestions appreciated!
Oh and I’m asking this before I apply the proposed “fix” as the problem is inconsistent and I dont really understand what is going on yet, so keen to get ideas from the community.
Hi again All,
So one of my units had this issue during testing we’ve been doing to try and characterise the original problem. Very strange: It completely failed to respond to any radio transmissions, even after rebooting multiple times via removing and replacing the batteries. I thought the micro might have failed (even though the light was still on) so I tested using USB only. Absolutely fine. It has now been running via batteries for several days without skipping a beat. Any suggestions??
Also I’ve found a couple of references to an OnReceive callback issue with the DIO0 interrupt pin getting stuck high on the old SX: https://github.com/sandeepmistry/arduino-LoRa/issues/447
Anyone know if this is a problem for the CC-AB01s?
Ive also found this issue specifically for the SX1262s:
Anyone know how we can access the DIO1 pin on the SC1262 to check it?
Hi All,
Answering my own question here: The solution I found was to reinitialise the radio after each reception/transmission cycle for my nodes et al (gets a command, sends a response). I’m not super happy about this solution as can see a few potential issues but has been working reliably so far.
You might want to try out an alternative library. Personal favourite is RadioLib but there are more choices.
you can also check Radiohead library which recently start to work with CubeCell
https://www.airspayce.com/mikem/arduino/RadioHead/
https://www.airspayce.com/mikem/arduino/RadioHead/RadioHead-1.142.zip
Thanks. Very good to know. Funny but true: my original code with a different board was all written with RH. I moved to the heltec libs cause none of my RH code worked at the time!
I haven’t tried it. Will take a look.
