Capture and analyze LoRaWAN packets
How to capture LoraWAN packets before transmit and then save in a microSD for example?
I have a Wireless Stick Lite, and I dont know if it’s posible. The purpose is for open the LoraWan packets in Wireshark.
Best regards.
Do you mean to capture lorawan packets with wireshark?
Capture lorawan packets in arduino code. Then, save the packets in a microSD memory or transmit directly to PC and save in .pcap. Finally, open the .pcap file with Wireshark.
I have a Wireless Stick Lite , and I dont know how I can do this.
Find the sending code and add the code saved on the SD card before it.
not sure, if it’s what you are asking for… But:
I build an Arduino sketch that receives a LoRa data packet and calls a PHP script on a computer. This PHP script formats and write the received data into an ASCII txt file. I used two Heltecs boards with LoRa, Oled an WiFi on board. First board is the node with a temp sensor and second board is the gateway to the computer.
