Hello!
I’m trying to connect my Wireless Stick to Chirpstack using the LoRaWAN example code provided right here, which I can access through Arduino IDE.
I have followed the Heltec tutorial, but still couldn’t do it, so I wish I could get some help.
I’m using LoRaWAN Region AU915.
Below is my code:
#include "LoRaWan_APP.h"
/* OTAA para*/
uint8_t appKey[] = { 0xd0, 0x67, 0x84, 0x81, 0x64, 0x57, 0x12, 0x87, 0xc3, 0x45, 0x1d, 0x67, 0xf6, 0x8c, 0x71, 0x9b };
/* ABP para*/
/*OTAA or ABP*/
/*ADR enable*/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
appDataSize = 4;
appData[0] = 0x00;
appData[1] = 0x01;
appData[2] = 0x02;
appData[3] = 0x03;
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
Mcu.begin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
I believe I configured everything right in Chirpstack: DevEUI, AppKey, OTAA Support, LoraWAN MAC Version, etc.
I cannot see Join Requests nor Join Accepts in the live frames.
My gateway is a RAK 2287.
This is some of the debugging at Serial Monitor:
LoRaWAN AU915 Class A start!
+OTAA=1
+Class=A
+ADR=1
+IsTxConfirmed=1
+AppPort=2
+DutyCycle=15000
+ConfirmedNbTrials=4
+ChMask=0000000000000000000000FF
+DevEui=2232330000888802(For OTAA Mode)
+AppEui=0000000000000000(For OTAA Mode)
+AppKey=D067848164571287C3451D67F68C719B(For OTAA Mode)
+NwkSKey=15B1D0EFA463DFBE3D11181E1EC7DA85(For ABP Mode)
+AppSKey=D72C78758CDCCABF55EE4A778D16EF67(For ABP Mode)
+DevAddr=007E6AE1(For ABP Mode)
joining…
TX on freq 916200000 Hz at DR 5
Event : Tx Done
RX on freq 926300000 Hz at DR 13
Event : Rx Timeout
RX on freq 923300000 Hz at DR 8
Event : Rx Timeout
TX on freq 915600000 Hz at DR 2
Event: Tx Done
RX on freq 924500000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 916000000 Hz at DR 5
Event : Tx Done
RX on freq 925700000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
TX on freq 915200000 Hz at DR 2
Event : Tx Done
RX on freq 923300000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 915400000 Hz at DR 5
Event : Tx Done
RX on freq 923900000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
TX on freq 915800000 Hz at DR 2
Event : Tx Done
RX on freq 925100000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
TX on freq 916600000 Hz at DR 5
Event : Tx Done
RX on freq 927500000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
TX on freq 916400000 Hz at DR 2
Event : Tx Done
RX on freq 926900000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
TX on freq 916600000 Hz at DR 2
Event : Tx Done
RX on freq 927500000 Hz at DR 10
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
TX on freq 915800000 Hz at DR 5
Event : Tx Done
RX on freq 925100000 Hz at DR 13
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
join failed, join again at 30s later
Event : Tx Done
Event : Rx Timeout
