Hi there
I use the WiFi LoRa 32 V1-Module.
It is possble to use the LoRa Ports for digital Inputs or Outputs?
How I can setting the board?
Thanks for your answer
Best regards
Martin
Hi there
Best regards
Martin
You can use those pins without using the lora function. Just set the other pins as you normally would.
Dear Quency
Thanks for your answer.
When I use the Pins for Inputs ( GPIO 32,33,26,27) then it works.
Best regards
Martin
