Can I keep output in sleep mode?
I’m using CubeCell – Dev-Board Plus (HTCC-AB02).
Sleep mode is good.
But there is one have problem.
If I going to sleep mode, OUTPUT ports are initialize.
But I want keep OUTPUT mode. HIGH or LOW.
Do you have other sleep mode example?
Most GPIOs will not be initialized after Cubecell enters low power consumption. (the state before entering low power mode can be maintained)…
You may happen to use pins that will initialize after entering low power consumption.
you can try GPIO5.
