Hi all,
I have the CubeCell-1/2AAA Node (HTTC-AB02A) and want to use it as a low power temperature sensor with BME280. This is what I did so far:
- Running the 3rd Party BME280 Example: running fine. But this is not using the LowPower library.
- Combining the BME280 Example with Low power: Running fine, but only if I do not shut down the Vext after Transmission:
- When I do not shut down the Vext after transmission, I see that during LowPower Mode, the current is around 1.2 mA on 1/2 AAA battery
- When I shut down the Vext after transmission on battery, in LowPower mode i see the expected 4-6 uA, but unfortunatly bme readings are not stable. Sometimes the chipId can not be obtained durion bme.init(), or the sensor data are garbage giving always the same numbers, which is 90% of the cases.
- When I run the example not from battery but from USB, everything works fine, even if I shut down the Vext after transmission.
After reading the forum, I see related topics, but I could not figure out how that solve my problem:
In fact I start the transmission with Wire.begin() and end it with Wire.end() as proposed by @sbmiller / @rsmedia discussed in the linked topics.
Below my source code for better understanding what I’m doing:
#include "Arduino.h"
#include "Seeed_BME280.h"
#include "LoRaWan_APP.h"
#define DEVICE_ID 0x2
#define DEBUG
#define TX_OUTPUT_POWER 4// dBm
#define timetillsleep 100
#define timetillwakeup 180*1000 //3 min. sleep
static TimerEvent_t sleep;
static TimerEvent_t wakeUp;
uint8_t lowpower=1;
#define RF_FREQUENCY 434000000 // Hz
#define LORA_SPREADING_FACTOR 9 // [SF7..SF12]
#define LORA_CODINGRATE 3 // [1: 4/5,
#define RX_TIMEOUT_VALUE 1000
#define BUFFER_SIZE 16 // Define the payload size here
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
uint8_t humidity;
float temperature;
uint32_t pressure;
void onSleep()
#ifdef DEBUG
Serial.printf("Going into lowpower mode, %d ms later wake up.\r\n",timetillwakeup);
lowpower=1;
//timetillwakeup ms later wake up;
TimerSetValue( &wakeUp, timetillwakeup );
TimerStart( &wakeUp );
void onWakeUp()
#ifdef DEBUG
Serial.printf("Woke up, %d ms later into lowpower mode.\r\n",timetillsleep);
lowpower=0;
BME280 bme280;
digitalWrite(Vext, LOW);
delay(500);
Wire.begin();
#ifdef DEBUG
Serial.println("BME init");
if(!bme280.init()){
#ifdef DEBUG
Serial.println("Device error!");
delay(500);
temperature=bme280.getTemperature();
pressure=bme280.getPressure()/100;//hPa
humidity=bme280.getHumidity();
#ifdef DEBUG
Serial.print("Temp: ");
Serial.print(temperature);
Serial.print("C");
Serial.print("Humidity: ");
Serial.print(humidity);
Serial.println("%");
Wire.end();//without that, the bme.init() fails in most cases
// Vext OFF
digitalWrite(Vext, HIGH);//without that, current consumption in sleep is too high
txpacket[0]=DEVICE_ID; //uniqe device id
double dt1, dt2;
dt2=modf(temperature+100, &dt1);
txpacket[1]=dt1;//saves the non comma values
txpacket[2]=(uint8_t)(dt2*100);//save temp fraction
txpacket[3]=humidity;
txpacket[4]=pressure;
#ifdef DEBUG
Serial.printf("\r\nsending packet: ");
for (int i=0; i<BUFFER_SIZE; i++)
Serial.printf("%d ", txpacket[i]);
Serial.println();
delay(200);
Radio.Sleep();
#ifdef DEBUG
Serial.printf("Execution time is: %d\n", (endTime-startTime));
TimerStart( &sleep );
#ifdef DEBUG
pinMode(Vext, OUTPUT);
boardInitMcu( );
Radio.Init( &RadioEvents );
Radio.Sleep( );
TimerInit( &sleep, onSleep );
onWakeUp();
if(lowpower){
lowPowerHandler();
I hope you guys have some hints for me how to trace down/solve the issue.
/mcgreg
