Hi All,
I have a project I’m working on using a ESP32 Dev Module (mini-1). This project uses 74% of the resources.
“Sketch uses 976874 bytes (74%) of program storage space. Maximum is 1310720 bytes.
Global variables use 32564 bytes (9%) of dynamic memory, leaving 295116 bytes for local variables. Maximum is 327680 bytes.”
When I remove the BT capability the resources got down to 45%. These are my included libraries
#include “esp_bt_main.h”
#include “esp_bt_device.h”
#include “BluetoothSerial.h”
Is there a more efficient way to achieve this, I want to be around 55-65%, a 10-20% reduction.
What other info do you need from me so as to be able to help?
CODE BELOW (is there a better way to paste into a post):
// this header is needed for Bluetooth Serial -> works ONLY on ESP32
#include <stdio.h>
//-#include “esp_bt_main.h”
#include <SPI.h>
//-#include <Wire.h>
//-#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// “HSPI” Declaration for SSD1306 display connected using software SPI (default case):
// 2.5" OLED connections on prototype PCB
#define OLED_MOSI 13 //GPIO13, PIN 19 to Disp Conn Pin 5 (DI)
#define OLED_CLK 14 //GPIO14, PIN 15 to Disp Conn Pin 4 (CLK)
#define OLED_DC 2 //GPIO02, PIN 21 to Disp Conn Pin 16(DC)
#define OLED_CS 15 //GPIO15, PIN 20 to Disp Conn Pin 12(CS)
#define OLED_RESET 4 //GPIO04, PIN 23 to Disp Conn Pin 14(RES)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT,
OLED_MOSI, OLED_CLK, OLED_DC, OLED_RESET, OLED_CS);
const int Analog_channel_pin= 36; //adc1_ch0
const int button1 = 21; // SW1 GPIO21
const int button2 = 23; // SW2 GPIO23
const int button3 = 18; // SW3 GPIO18
const int button4 = 5; // SW4 GPIO05
#define AVG 10
#define UPDATE 2000
#define LED1 32
#define LED2 33
#define LED3 25
#define HBEAT 4000
int ADC_VALUE = 0;
float voltage_value = 0;
char dewpoint[8];
int SW1_state,SW2_state,SW3_state,SW4_state;
int curr_sw;
int led_no=0;
char dev_addr[3]; //last two of MAC for name
char btName[20] = “XDTII_”;
// init Class:
BluetoothSerial ESP_BT;
// Parameters for Bluetooth interface
int units = 0; //0=C, 1=F, 2=ppmV
void printDeviceAddress() {
char str[3];
const uint8_t* point = esp_bt_dev_get_address();
for (int i = 0; i < 6; i++) {
sprintf(str, "%02X", (int)point[i]);
Serial.print(str);
if (i < 5){
Serial.print(":");
dev_addr[0]=str[0];
dev_addr[1]=str[1];
dev_addr[2]=str[2];
Serial.println();
Serial.println(dev_addr);
int read_switches(void)
int SW_value;
SW1_state = digitalRead(button1);
SW2_state = digitalRead(button2);
SW3_state = digitalRead(button3);
SW4_state = digitalRead(button4);
SW1_state = !SW1_state; SW2_state = !SW2_state; SW3_state = !SW3_state; SW4_state = !SW4_state;
SW_value = SW4_state222 + SW3_state22 + SW2_state2 + SW1_state;
return SW_value;
void init_display(void)
display.setRotation(2); //0=0, 1=90, 2=180, 3=270
display.clearDisplay();
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(12,0); // Start at top-left corner
display.println(F(“Cosa Xentaur XDTII”));
//display.setTextColor(SSD1306_BLACK, SSD1306_WHITE); // Draw ‘inverse’ text
//display.println(3.141592);
display.println("");
display.setTextSize(1); // Draw 2X-scale text
// display.print(F(“0x”));
display.setCursor(6,10); // Start at top-left corner
display.println(F(“Code Rev p1 05/22/23”));
mainMenu();
display.display();
// delay(2000);
void setup()
Serial.begin(19200);
pinMode(button1, INPUT);
pinMode(button1, INPUT_PULLUP);
pinMode(button2, INPUT);
pinMode(button2, INPUT_PULLUP);
pinMode(button3, INPUT);
pinMode(button3, INPUT_PULLUP);
pinMode(button4, INPUT);
pinMode(button4, INPUT_PULLUP);
pinMode(LED1, OUTPUT);
digitalWrite(LED1, LOW);
pinMode(LED2, OUTPUT);
digitalWrite(LED2, LOW);
pinMode(LED3, OUTPUT);
digitalWrite(LED3, LOW);
led_no=0;
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
init_display();
// btName = “XDTII_”;
ESP_BT.begin(“BT_IF”); //Name of your Bluetooth interface -> will show up on your phone
printDeviceAddress();
strcat(btName,dev_addr);
// ESP_BT.begin(“ESP32_Interface”); //Name of your Bluetooth interface -> will show up on your phone
ESP_BT.begin(btName); //Name of your Bluetooth interface -> will show up on your phone
// printDeviceAddress();
attachInterrupt(digitalPinToInterrupt(21),sw_int,FALLING); //SW1
attachInterrupt(digitalPinToInterrupt(23),sw_int,FALLING); //SW2
attachInterrupt(digitalPinToInterrupt(18),sw_int,FALLING); //SW3
attachInterrupt(digitalPinToInterrupt(5) ,sw_int,FALLING); //SW4
static int hb_cnt=0;
static bool hb_sts=0;
int bt_sw=0;
// -------------------- Receive Bluetooth signal ----------------------
if (ESP_BT.available())
units = ESP_BT.read(); //Read what we receive
Serial.println(units);
bt_sw = ESP_BT.read(); //Read what we receive
Serial.println(bt_sw);
if (bt_sw) //non-zero
display.setCursor(0,40); // Start at top-left corner
display.println(F("SW = "));
display.setCursor(30,40); // Start at top-left corner
display.println(bt_sw);
switch(bt_sw)
case 1:
Menu1_1();
case 2:
Menu1_2();
case 3:
Menu1_3();
case 4:
Menu1_4();
mainMenu();
bt_sw = 0; //reset
process_switches();
process_dewpoint();
if(hb_cnt++ > HBEAT)
hb_cnt=0;
hb_sts = !hb_sts;
switch(led_no)
case 0:
digitalWrite(LED1, hb_sts);
digitalWrite(LED2, 0);
digitalWrite(LED3, 0);
case 1:
digitalWrite(LED2, hb_sts);
digitalWrite(LED1, 0);
case 2:
digitalWrite(LED3, hb_sts);
led_no=-1;
led_no++;
void process_dewpoint(void)
char disp_buf[8];
static int avg_cnt, dsp_cnt=0;
voltage_value += ReadVoltage(Analog_channel_pin);
if(avg_cnt++ > (AVG-2))
voltage_value /= AVG;
// ESP_BT.println(dewpoint); //send data
//Put numeric dewpoint on the display
if(dsp_cnt++ > (UPDATE))
//**************************Clear numeric area *****************
//display.drawRect(60, 45, 67, 21, WHITE); //test size
display.fillRect(60, 45, 67, 21, BLACK);//clear
display.display();
display.setTextSize(2);
display.setCursor(0,50); // set cursor pos textsize(1)
//display.print("Dewpoint = ");
display.print("DewPt=");
display.setTextSize(2); // Draw 2X-scale text
display.setCursor(60,50); // set cursor pos textsize(1)
//display.println(dewpoint);
sprintf(disp_buf,"%5s",dewpoint);
display.print(disp_buf);
display.display();
switch(units)
case 0:
voltage_value *= 3;
case 1:
voltage_value *= 6;
case 2:
voltage_value *= 9;
dsp_cnt=0;
} //display loop
//sprintf(dewpoint,"%3.3f",voltage_value);
dtostrf(voltage_value,3,2,dewpoint);
avg_cnt=0;
voltage_value = 0;
} //voltage loop
double ReadVoltage(byte pin)
double reading = analogRead(pin); // Reference voltage is 3v3 so maximum reading is 3v3 = 4095 in range 0 to 4095
// Serial.print("ADC VALUE = ");
// Serial.println((int)reading);
if(reading < 1 || reading > 4095) return 0;
return -9e-15 * pow(reading,4) + 5e-11 * pow(reading,3)- 1e-7 * pow(reading,2) + 0.0009 * reading + 0.1064;
// return - 2e-11 * pow(reading,3) + 1e-7 * pow(reading,2) + 0.0007 * reading + 0.1336;
} // Added an improved polynomial, use either, comment out as required
void sw_int(void)
//int curr_sw;
curr_sw = read_switches();
void process_switches(void)
if (curr_sw) //non-zero
display.println(curr_sw);
switch(curr_sw)
case 1:
Menu1_1();
case 2:
Menu1_2();
case 4:
Menu1_3();
case 8:
Menu1_4();
curr_sw = 0; //reset
void mainMenu(void)
display.setCursor(0,0); // Start at top-left corner
display.print(“SW1 Opt”);
display.setCursor(86,0); // Start at top-left corner
display.print(“Set SW2”);
display.setCursor(0,20); // Start at top-left corner
display.print(“SW3 Units”);
display.setCursor(74,20); // Start at top-left corner
display.print(“Calib SW4”);
display.display();
void Menu1_1(void)
Serial.print(“Menu Item 1:1”); //debug
//digitalWrite(LED1, LOW);
display.setCursor((SCREEN_WIDTH-60)/2,SCREEN_HEIGHT/2); // Start at top-left corner
display.print(“Menu 1:1”);
display.display();
mainMenu();
void Menu1_2(void)
Serial.print(“Menu Item 1:2”); //debug
//digitalWrite(LED1, HIGH);
display.print(“Menu 1:2”);
display.display();
mainMenu();
void Menu1_3(void)
Serial.println(“Menu Item 1:3”); //debug
if(units<2)
units++;
else
units=0;
display.print(“Menu 1:3”);
display.display();
mainMenu();
void Menu1_4(void)
Serial.print(“Menu Item 1:4”); //debug
display.print(“Menu 1:4”);
display.display();
mainMenu();
