Here is my final code, it works nice.
Sorry if this is very basic, I’m a noob.
#include <CoinMarketCapApi.h>
- An example of getting ticker info from coinmarketcap.com *
- Written by Brian Lough *
//------- Install From Library Manager -------
#include <ArduinoJson.h>
#include <WiFi.h>
#include <WiFiClientSecure.h>
#include <Wire.h>
#include <U8g2lib.h>
U8X8_SSD1306_128X64_NONAME_SW_I2C u8x8(15,4,16);
//------- Replace the following! ------
char ssid[] = “S S I D”; // your network SSID (name)
char password[] = “P A S S W R D”; // your network key
WiFiClientSecure client;
CoinMarketCapApi api(client);
// CoinMarketCap’s limit is “no more than 10 per minute”
// Make sure to factor in if you are requesting more than one coin.
unsigned long api_mtbs = 60000; //mean time between api requests
unsigned long api_due_time = 0;
u8x8.begin();
u8x8.setPowerSave(0);
// Attempt to connect to Wifi network:
Serial.print("Connecting Wifi: ");
u8x8.begin();
u8x8.setFont(u8x8_font_5x7_f);
// u8x8.drawString(0,0,“Hello World!”);
u8x8.refreshDisplay(); // only required for SSD1606/7
delay(500);
u8x8.drawString(0,0,“ConnectingWifi:”);
delay(100);
Serial.println(ssid);
u8x8.drawString(0,1,ssid);
delay(100);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println("");
Serial.println(“WiFi connected”);
u8x8.drawString(0,3,“WiFi connected”);
Serial.println("IP address: ");
IPAddress ip = WiFi.localIP();
Serial.println(ip);
u8x8.setCursor(0, 4);
u8x8.print(ip);
u8x8.drawString(3,6,“H O D L”);
delay(2500);
u8x8.clear();
void printTickerData(String ticker) {
u8x8.begin();
delay(200);
Serial.println("---------------------------------");
Serial.println("Getting ticker data for " + ticker);
// Ticker unfortunately is not the symbol for some reason.
// Go to CoinMarketCap.com and select the coin you would like to check
// The ticker name makes up the last part of the URL
// e.g: http://coinmarketcap.com/currencies/bitcoin/ , “bitcoin” is the ticker value
// Currency is optional, so you can pass only ticker if you want.
// Check out the currency drop down on CoinMarketCap.com to get available values
CMCTickerResponse response = api.GetTickerInfo(ticker, “eur”);
if (response.error == “”) {
Serial.print("ID: ");
Serial.println(response.id);
Serial.print("Name: ");
Serial.println(response.name);
Serial.print("Symbol: ");
Serial.println(response.symbol);
Serial.print("Rank: ");
Serial.println(response.rank);
Serial.print("Price in USD: ");
Serial.println(response.price_usd);
Serial.print("Price in BTC: ");
Serial.println(response.price_btc);
Serial.print("24h Volume USD: ");
Serial.println(response.volume_usd_24h);
Serial.print("Market Cap USD: ");
Serial.println(response.market_cap_usd);
Serial.print("Available Supply: ");
Serial.println(response.available_supply);
Serial.print("Total Supply: ");
Serial.println(response.total_supply);
Serial.print("Percent Change 1h: ");
Serial.println(response.percent_change_1h);
Serial.print("Percent Change 24h: ");
Serial.println(response.percent_change_24h);
Serial.print("Percent Change 7d: ");
Serial.println(response.percent_change_7d);
Serial.print("Last Updated: ");
Serial.println(response.last_updated);
// These fields will not come back if you do not request a currency
Serial.print("Price in requested currecy: ");
Serial.println(response.price_currency);
Serial.print("24h Volume in requested currency: ");
Serial.println(response.volume_currency_24h);
Serial.print("Market Cap in requested currency: ");
Serial.println(response.market_cap_currency);
//show it on the screen =
u8x8.setCursor(0, 0);
u8x8.print(response.name);
u8x8.drawString(0, 1,"USD: ");
u8x8.setCursor(8, 1);
u8x8.print(response.price_usd);
u8x8.drawString(0, 2,"1hr %: ");
u8x8.setCursor(8, 2);
u8x8.print(response.percent_change_1h);
u8x8.drawString(0, 3,"24hr %: ");
u8x8.setCursor(8, 3);
u8x8.print(response.percent_change_24h);
u8x8.drawString(0, 4,"7day %: ");
u8x8.setCursor(8, 4);
u8x8.print(response.percent_change_7d);
u8x8.drawString(0, 5,"Rank: ");
u8x8.setCursor(8, 5);
u8x8.print(response.rank);
delay(8000);
} else {
Serial.print(“Error getting data: “);
Serial.println(response.error);
Serial.println(”---------------------------------”);
// u8x8.begin();
// u8x8.setPowerSave(0);
// u8x8.setFont(u8x8_font_chroma48medium8_r);
// u8x8.refreshDisplay(); // only required for SSD1606/7
// delay(2000);
unsigned long timeNow = millis();
if ((timeNow > api_due_time)) {
printTickerData(“litecoin”);
printTickerData(“ethereum”);
printTickerData(“dero”);
printTickerData(“bitcoin”);
api_due_time = timeNow + api_mtbs;
