Hello there!
We are wondering about what batteries might be most suitable for the AB01.
We’re building a device which won’t be rechargeable, which means we’d rather not use LiPo batteries (as they are relatively expensive, and a waste when it cannot be recharged).
One thing we’d like to know, is if LiSOCl2-batteries can be used with the AB01. We know that the AB02AA is intended for a similar battery. However, we’re not using that board because we need to use a smaller internal antenna.
So our questions:
- When attaching a battery through the
SH1.25-2-connector, is it voltage-regulated or not? Do we need to look at the ‘Lithium-powered’/VBAT rows in the usage sheet, or at the 3V3 rows?- In other words: When connecting a battery through the connector, will we have a sleep current of 11µA or 3.4µA? And do we need to supply a peak current of >=250mA or >= 150mA?
- If the connector uses VBAT: Is there a possibility to connect such batteries (which have a max voltage of 3.6V and nominal voltage of 3.55V) to the 3V3 pin to realize the lower sleep current and peak current requirements, or will this damage the board?
- Are there other (high energy density) batteries that work well with the AB01?
