I’m making my own Lora board using a HTCC-AM01 module (for arduino).
The question is:
To read battery voltage is necessary use this scheme or I can connect directly the battery to adc pin?
The question is:
hi,
The ASR6501’s ADC pin can bear MAX Voltage is 2.4V.
I understood, but if I want to check the battery voltage without GPIO pin (without mosfet). What is the most simple circuit?
This is the battery ADC read in HTCC-AB01:
If I remove the mosfet and GPIO 7, can I use this circuit to check the voltage of battery?
Thanks,
XCO
hi,
yes ,the anwser is Yes.
but This will affect low power consumption
Ok very clear, I checked the source code and I understood the function of GPIO 7.
I’ll use se same schema of HTCC-AB01 (ADC battery) for make my HTCC-AM01 board (but i’ll remove the R13).
Thanks,
XCO
