Here is the same transmit code with the BME280 sensor. It works OK, but I cannot implement so far the VEXT and the LowPower_Handler() functions. It seems that the I2C connection of my BME280 sensor gets lost.
With this code the CellCube board and the sensor consume 12 mAh, what is a bit too much for the battery set-up. The VCC of the BME280 sensor is connected to the VEXT pin on the side of the board.
#include “LoRaWan_APP.h”
#include “Arduino.h”
#include “Wire.h”
#include “BME280.h”
BME280 bme280;
#ifndef LoraWan_RGB
#define LoraWan_RGB 0
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
unsigned long time_now = 0;
unsigned long next_millis = 0;
int16_t txnumber;
int16_t RSSI, rxSize;
BoardInitMcu( );
pinMode(Vext, OUTPUT);
digitalWrite(Vext, LOW);
txnumber = 0;
RSSI = 0;
Radio.Init( &RadioEvents );
if (!bme280.init()) {
Serial.println(“Device error!”);
time_now = millis();
while (millis() < time_now + 500) { // equivalent of delay(…);
float temp = 0;
float humd = 0;
float prss = 0;
float altd = 0;
temp = bme280.getTemperature();
humd = bme280.getHumidity();
prss = bme280.getPressure();
altd = bme280.calcAltitude(prss);
//get and print temperatures
Serial.print("Temp: ");
Serial.print(temp);
Serial.println(“C”);//The unit for Celsius because original arduino don’t support speical symbols
//get and print humidity data
Serial.print(“Humidity: “);
Serial.print(humd);
Serial.println(”%”);
//get and print atmospheric pressure data
Serial.print("Pressure: ");
Serial.print(prss);
Serial.println(“Pa”);
//get and print altitude data
Serial.print("Altitude: ");
Serial.print(altd);
Serial.println(“m”);
uint16_t voltage = 0;
voltage = analogRead(ADC); //return the voltage in mV, max value can be read is 3300mV
Serial.println(voltage);
char *str_temp;
String msgT = “”;
msgT = String(temp, 1) + “#” + String(humd, 1) + “#” + String((prss / 100), 1) + “#” + String(altd, 1) + “#” + String(voltage);
memset(txpacket, 0, BUFFER_SIZE);
// converting strig to a char?
str_temp = (char*)(msgT).c_str();
sprintf(txpacket, “%s”, str_temp);
RGB_ON(COLOR_SEND, 0);
Serial.printf("\r\nsending packet “%s” , length %d\r\n", txpacket, strlen(txpacket));
Radio.Send( (uint8_t *)txpacket, strlen(txpacket) );
RGB_ON(0, 0);
while (millis() < time_now + 10000) {
