AT commands over LoRa
Has anyone implamented a routine that allows you to transmit the AT commands directly over LoRa?
It occured to me that instead of writing a bunch of code to change things such as the DutyCycle etc it would be nice to handle the incoming data on a selected channel as AT commands ?
Sorry, the AT command cannot be used through lorawan. The known way is to switch the CLASS through the node’s own.
Thanks Jason, Yea i was aware that the AT command as it is will not work via LoRa as it is but was wondering if it was possible to inject the commands directly to the AT class. When i get some free time may have a look and give it a try. Could be kind of cool to be able tp have a feature like this.
