Hi everybody.
I’m trying to implement a freertos in the cellcube module for LoRa, which uses asr6501 mcu. Do you know if is possible or i need an external mcu which controls the psoc+lora module?
Thanks in advance.
Hi everybody.
Thanks in advance.
Interesting idea! Can you share some more details? Second development based on Arduino?
But as far as I know, I think this operation is a little hard. Complete porting the LoRaWAN stack is a large scale work, most unfortunately, ASR packed some timer relevant codes…
Hi everybody.
At last, I implemented the CellCube being controlled by a STM32 by a serial port, using AT commands. I had to code in IAR a driver which sends commands and read responses, comparing strings and checking if communicacion is successful.
Great operation!
At least this can avoid the huge workload of migration the complete LoRaWAN protocol to the STM32 chip
