Are my AB02 boards dead?
I have two HTCC-AB02 boards which I am having issues with.
both have the same code uploaded to them, but give different results.
I have tried uploading from both Arduino IDE and Platform IO - no difference.
Code is below:
#include "LoRaWan_APP.h"
#include <Wire.h>
#include "HDC1080.h"
#define rainPin GPIO1
int rain = 0;
int finalrain = 0;
uint16_t vbat;
uint16_t cnt;
void cntIncrease();
 * RGB red means sending;
 * RGB blue means RxWindow1;
 * RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t devEui[] = { 0x70, 0xB3, 0xD5, 0x7E, 0xD0, 0x06, 0x04, 0x7B};
//generic_meshed_testing app
uint8_t appEui[] = { 0xA1, 0xB2, 0xC3, 0xD4, 0xE5, 0xF6, 0xC69, 0x69};
uint8_t appKey[] = {XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX};
/* ABP para*/
uint32_t devAddr =  ( uint32_t )0x007e6ae1;
DeviceClass_t  loraWanClass = LORAWAN_CLASS;
/*the application data transmission duty cycle.  value in [ms].*/
uint32_t appTxDutyCycle = 300000;
/*OTAA or ABP*/
/*ADR enable*/
/* Application port */
uint8_t appPort = 1;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
 * \brief   Prepares the payload of the frame
HDC1080 hdc1080;
    pinMode(Vext,OUTPUT);
    digitalWrite(Vext,LOW);
    hdc1080.begin(0x40);
    float temperature = (float)(hdc1080.readTemperature());
    float humidity = (float)(hdc1080.readHumidity());
    hdc1080.end();
    digitalWrite(Vext,HIGH);
    uint16_t vbat = getBatteryVoltage();
    unsigned char *puc;
    puc = (unsigned char *)(&temperature);
    appDataSize = 12;
    appData[0] = puc[0];
    appData[1] = puc[1];
    appData[2] = puc[2];
    appData[3] = puc[3];
    puc = (unsigned char *)(&humidity);
    appData[4] = puc[0];
    appData[5] = puc[1];
    appData[6] = puc[2];
    appData[7] = puc[3];
    appData[8] = (uint8_t)(vbat>>8);
    appData[9] = (uint8_t)(vbat);
    appData[10] = (uint8_t)(cnt>>8);
    appData[11] = (uint8_t)(cnt);
    Serial.print("T=");
    Serial.print(temperature);
    Serial.print("C, RH=");
    Serial.print(humidity);
    Serial.print("%,");
    Serial.print("BatteryVoltage:");
    Serial.println(vbat);
		 PINMODE_INPUT_PULLUP(GPIO1);
  attachInterrupt(GPIO1,cntIncrease,FALLING);  /* pin to interup, ISR (interupt rouint function), mode(falling or rising) */
#if(AT_SUPPORT)
	enableAt();
	LoRaWAN.ifskipjoin();
	switch( deviceState )
		case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
#if(AT_SUPPORT)
			getDevParam();
			printDevParam();
		case DEVICE_STATE_JOIN:
			LoRaWAN.join();
		case DEVICE_STATE_SEND:
			prepareTxFrame( appPort );
			LoRaWAN.send();
		case DEVICE_STATE_CYCLE:
		case DEVICE_STATE_SLEEP:
			LoRaWAN.sleep();
void cntIncrease() {
  static unsigned long last_interrupt_time = 0;
  unsigned long interrupt_time = millis();
  // If interrupts come faster than 250ms, assume it's a bounce and ignore
      if (interrupt_time - last_interrupt_time > 500)
          cnt++;
      last_interrupt_time = interrupt_time;
AB02 number one will try and join, but will always fail. It will try different frequencies, but always with DR 5. (other boards I have cycle through different DR values until join is successful)
AB02 number 2 will accept a successful upload, but then does nothing. pressing the reset button only gives the serial output : ‘Copyright @2019-2020 Heltec Automation.All rights reserved.’
pressing and holding ‘USR’ while pressing and releasing ‘RST’ gives ‘bootloader Rev 1.0’.
Running the same code on a board that is known to be working gives expected results.
Am I to accept that these two boards are just dead now?
EDITED: Board AB02 number 2 is now working correctly, I have no idea why, the only difference is that i used platform io to upload the sketch and it now works and sends data via TTN as desired!
Board AB02 number one is still stuck on trying to join at DR5 with no success…
Same bahaviour when connected to usb ?
yes, i now believe that the board abo2 number 2 has an issue with the lorawan chip, as i uploaded the factory test sketch from arduino ide, and it wont get past displaying ‘Lorawan Starting’ on the oled display
