Hello!
I try to install support for AB01 in Arduino IDE board manager. But I get an error when downloading “gcc-arm-none-eabi-8-2019-q3-update-win32.zip”. What can be the problem?
//Erik
Arduini IDE board manager error
I am having the same issue, looks like there may be a corruption in the file.
You can try to input the site.
https://github.com/HelTecAutomation/CubeCell-Arduino/releases/download/V1.3.0/package_CubeCell_index.json
Hello!
Does anyone know how to make it work with the Arduino IDE? Also tried with Git, but it does not work.
//Erik
You can follow this document.
https://heltec-automation-docs.readthedocs.io/en/latest/cubecell/quick_start.html
Yes I did folow this guide, problem is that one of the files that Arduino IDE downloads are corruped. CRC dont match.
Thanks for your awnser!
Br. Erik
You delete the original json file, and then try it.
Now it works. It was a server problem.
Br. Erik
“Dear Erik
Very sorry about this problem, we had fixed the resource server limited problem, please try again.
Regards.Aaron.Lee”
