On which connector do I connect my Lora antenna ?
The upper left connector or the other ?
Antenna Wireless Shell
Thank you very much…
This is quite confusing… If I put my Wireless Shell 868 Mhz at the same position as in picture above the solder pads on the short edge of the PCB are on the left hand side. Which one of the IPEX connecors is for LoRa? Do you have different versions of the PCB or is the sticker assembled inccorrectly in my case? Please give me a clear and unambiguous explanation how to identify the LoRa antenna connector!
then only the sticker is wrong.
lay the shell in front of you. the short side with the contact to the right, like the picture above.
The WiFi connector is on the short side of the PCB with the contacts.
The LoRa connector on the opposite site.
ok, thank you. For me it still very strange that you have the sticker positioned in two different ways, it does not give any reliable feeling of the product…
it is only a sticker.
a sticker says nothing about the product.
i can make a great looking label for a cheap bottle of wine, but the wine will be cheap.
