Is there a comparison of the differences between the old/new GPS chip used for the new AB02S?
AIR530 vs AIR530Z
Browse through or search this site. Jason posted their comparizon.
Thank you Jason. I saw the announcement and hoped to get more detailed information regarding the capability of the Air530Z and how to program it. Is there a link with a technical description of the Air530Z available? Could not Google one…
Thank you - as usual, Google Translate did a great job…
Is the schematic diagram from the docs & resource section still correct for the boards with A530Z?
Yes!
As there are some differences between Air530 and Air520Z pin layout/functions it would be good to know the following:
- Pin 1 & 2 - active antenna supported now?
- Pin 3 ON_OFF - connected to an IO pin or still shutdown via VECT needed?
- Pin 11 BDS_GLONASS - unconnected?
Thanks for the help in advance…
1.Pin 1–Support active antenna;
2.Pin 3 NOT connected to IO, shutdown still needs to control Vext;
3Pin 11–NOT connected.
Hope it can help you.
Your confirmation did help me a lot Xiao-H. Thank’s a lot.
Can i order the new Bord with A520Z here in the shop?
I’ve got this board with the Air530Z GPS. As i’m situated in europe, i wanted to activate the use of the european GPS system
Galileo.
In other forum posts i see that the Air530 supported this GPS system. Is this also a difference between Air530 and the Air530Z module?
Although in the datasheet there is a mention of “Galileo”…
