i had a problem with the ADR-funktion on LoRaWAN!
The Sensor had no connection to a gateway, after ADR_ACK_LIMIT= 64 + ADR_ACK_DEIAY = 32 attempts (EU868)
the Cubecell changing the broadcasting scheme from SF7 to SF8.
Then three packets are received!
SNR 10.8, 10.5, 10.8
RSSI -130, -132, -130,
After that, no more packets are received!
So what happend there?
E_T
Update:
After ca. 130 (possible) packets two packets arrived with SF9
SNR -11.8, -13.5
RSSI -132, -134
Update 2
Here the new values: Now we are on SF 11 but the signal performance deteriorates (weather-related?)
| Nr | Name | Date/Time | SF | SNR | RSSI | Date/Time |
| 835 | mk-cc19-hdc1080 | 2021-05-23T08:39:31.507900Z | 7 | -6,5 | -126 | 23.5.21 8:38 |
| 836 | mk-cc19-hdc1080 | 2021-05-23T08:39:42.789093Z | 7 | -6,2 | -125 | 23.5.21 8:38 |
| 843 | mk-cc19-hdc1080 | 2021-05-23T08:49:43.612780Z | 7 | -6,5 | -126 | 23.5.21 8:49 |
| 850 | mk-cc19-hdc1080 | 2021-05-23T08:59:44.892476Z | 7 | -4,5 | -124 | 23.5.21 8:59 |
| 874 | mk-cc19-hdc1080 | 2021-05-23T09:39:47.142414Z | 7 | -9 | -129 | 23.5.21 9:39 |
| 886 | mk-cc19-hdc1080 | 2021-05-23T10:09:49.530985Z | 7 | -6,8 | -128 | 23.5.21 10:09 |
| 1281 | mk-cc19-hdc1080 | 2021-05-24T01:30:32.330426Z | 8 | -10,5 | -130 | 24.5.21 1:29 |
| 1312 | mk-cc19-hdc1080 | 2021-05-24T02:30:40.984603Z | 8 | -12 | -132 | 24.5.21 2:29 |
| 1327 | mk-cc19-hdc1080 | 2021-05-24T03:00:45.013562Z | 8 | -11,5 | -132 | 24.5.21 3:00 |
| 1432 | mk-cc19-hdc1080 | 2021-05-24T06:41:12.477539Z | 9 | -12 | -133 | 24.5.21 6:40 |
| 2044 | mk-cc19-hdc1080 | 2021-05-25T01:32:16.505670Z | 8 | -12 | -131 | 25.5.21 1:31 |
| 2158 | mk-cc19-hdc1080 | 2021-05-25T04:31:38.337588Z | 9 | -12,5 | -134 | 25.5.21 4:31 |
| 2176 | mk-cc19-hdc1080 | 2021-05-25T05:01:42.483625Z | 9 | -12,2 | -132 | 25.5.21 5:01 |
| 2852 | mk-cc19-hdc1080 | 2021-05-25T21:12:35.833133Z | 8 | -10,8 | -130 | 25.5.21 21:12 |
| 2862 | mk-cc19-hdc1080 | 2021-05-25T21:22:37.370869Z | 8 | -10,5 | -132 | 25.5.21 21:22 |
| 2872 | mk-cc19-hdc1080 | 2021-05-25T21:32:38.274668Z | 8 | -10,8 | -130 | 25.5.21 21:32 |
| 3708 | mk-cc19-hdc1080 | 2021-05-26T19:04:17.008659Z | 9 | -11,8 | -132 | 26.5.21 19:03 |
| 3715 | mk-cc19-hdc1080 | 2021-05-26T19:14:17.384513Z | 9 | -13,5 | -134 | 26.5.21 19:13 |
| 3819 | mk-cc19-hdc1080 | 2021-05-26T22:04:35.778340Z | 9 | -13,2 | -133 | 26.5.21 22:03 |
| 3842 | mk-cc19-hdc1080 | 2021-05-26T22:34:40.840229Z | 9 | -13,2 | -133 | 26.5.21 22:34 |
| 3880 | mk-cc19-hdc1080 | 2021-05-26T23:34:45.760106Z | 9 | -13 | -131 | 26.5.21 23:34 |
| 3912 | mk-cc19-hdc1080 | 2021-05-27T00:24:51.674120Z | 10 | -14,2 | -134 | 27.5.21 0:24 |
| 3921 | mk-cc19-hdc1080 | 2021-05-27T00:34:53.802190Z | 11 | -15,8 | -135 | 27.5.21 0:34 |
