i’m using a Heltec heltec_wifi_lora_32_V2 - with default library provided by Heltec and the examples provides out of the git repository.
Everything connects fine; Display is fine - ABP Example is fine and running - but OTAA is not.
In the moment i switch the device in TTN to OTA and adapt the lines for the required keys:
/OTAA or ABP/
The device is stuck in a loop and i see the joining requests in TTN but never an answer is accepted.
Any suggestions?
ESP32 MCU init...
ESP32 MCU inited OK!
LoRaWAN EU868 Class A start!
joining...
TX on freq 868500000 Hz at DR 5
DIO0:TX Done
RX on freq 868500000 Hz at DR 5
DIO1:RX Timeout
TX on freq 868300000 Hz at DR 5
DIO0:TX Done
RX on freq 868300000 Hz at DR 5
DIO1:RX Timeout
TX on freq 868100000 Hz at DR 5
DIO0:TX Done
RX on freq 868100000 Hz at DR 5
DIO1:RX Timeout
DIO0:TX Done
