Hey guys, on the pinout diagram for the AB02S I see pins 8/9 are SCL1/SDA1, is this a second IIC bus? How do I use that bus? I am trying to connect a device to SCL/SDA and even tho it has a different address it conflicts with the OLED.
AB02S using SCL1/SDA1
Wire1 is the control function of I2C1. Not Wire.
Thank you, this solved it. For some reason it cant read the megnetometer from the MPU9250 but I can get the other data.
