I’m looking for a proposal for an AB02 solution able to communicate thru an ENC28J60 or W5100 based Ethernet shield. I have some leftovers from Arduino projects and would like to build up a simple gateway between LoRa and MQTT thru LAN.
Any help is appriciated.
Thank you.
AB02 + Ethernet
After hunting thru internet and reading a lot of specs I’m back at the Original Arduino Nano with Ethernet shield and external SX1276 module. Works fine so far.
b/r
