Hi All. I am trying to use the code examples to read and write in the EEPROM, but when compile the code, without modifications from examples, I have some error codes.
Someone just used it and could share some code to make this working please ?
I need to store some data one time only, and when in use in the setup read this two bytes as a device address…
I searched AB02 technical specification but EEPROM is not listed…First question is if it is avaliable in this device.
But tried a lot and don´t found the code error.
CubeCell/libraries/EEPROM/EEPROM.cpp:49:2: error: #else after #else
#else
/hardware/CubeCell/CubeCell/libraries/EEPROM/EEPROM.cpp:43: error: the conditional began here
#ifdef asr650x
/hardware/CubeCell/CubeCell/libraries/EEPROM/EEPROM.cpp:43: error: unterminated #else
exit status 1
Error compiling for board CubeCell-Board Plus(HTCC-AB02).
Regards and thank you for any support on this subject.
