I want to display my measurements for a few seconds after I took them and then send a uplink to the NS.
I have tried a few things and seems not anything from Dr. Google.
I cant seem to find the correct way to call the display.
Your help will be appriciated.
#include "LoRaWan_APP.h"
#include "Arduino.h"
//Display
#include <Wire.h>
#include "HT_SH1107Wire.h"
SH1107Wire display(0x3c, 500000, SDA, SCL ,GEOMETRY_128_64,GPIO10); // addr, freq, sda, scl, resolution, rst
* RGB red means sending;
* RGB blue means RxWindow1;
* RGB yellow means RxWindow2;
/* OTAA para*/
uint8_t devEui[] = { 0x3A, 0xE3, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appEui[] = { 0x3A, 0xE3, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00 };
uint8_t appKey[] = { 0xE3, 0x7E, 0x21, 0xD7, 0xA4, 0x60, 0x6F, 0x8E, 0x4E, 0x1B, 0x57, 0xA7, 0x7A, 0xDA, 0xA3, 0x9E };
/* ABP para*/
uint32_t appTxDutyCycle = 60000;
/*OTAA or ABP*/
/*ADR enable*/
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first) | DR
* 2 | DR
* 3 | max(DR-1,0)
* 4 | max(DR-1,0)
* 5 | max(DR-2,0)
* 6 | max(DR-2,0)
* 7 | max(DR-3,0)
* 8 | max(DR-3,0)
//Take measurements
uint16_t vBatt = getBatteryVoltage();
uint16_t uC =analogRead(ADC);
//Display measurements
display.drawString(0, 0, "V Batt = ");
display.drawString(0, 2, vBatt);
display.drawString(0, 6, "uC = ");
display.drawString(0, 8, uC);
delay(2000);
appDataSize = 2;
appData[0] = vBatt * 10;
appData[1] = uC*10;
boardInitMcu();
display.init();
#if(AT_SUPPORT)
enableAt();
LoRaWAN.ifskipjoin();
switch( deviceState )
case DEVICE_STATE_INIT:
#if(AT_SUPPORT)
getDevParam();
printDevParam();
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame( appPort );
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep();
display.stop();
detachInterrupt(RADIO_DIO_1);
