The Factory_test for the ESP32 Stick V3 and Cube Cell dev boards using Arduino 2.1.1 with V1.50 Cube Cell and V0.0.7 ESP32 Stick V3 rely on the device being plugged into a USB port with an active terminal as in two computers running Arduino with Serial Monitors active.
So even with an OLED display you still have to have an active terminal…
I was going to test the distance the LoRa + battery would travel…
The good news is all my boards work.
