I was gifted 2 HTIT-32 wifi boards. she got them at amazon. They both were working just fine with ws2812B LEDs then one day the Led screen on one board stopped but the board was still working at that point. The next day I plugged it back into the computer and I get a light but other than that it does not work. I started using the 2nd board and the same thing happened. The whole time from working to not working I never changed anything same LED’s same USB. My friend’s esp 32 works just fine on my setup. Please help.
2 boards stop working withen 2 days of oneanother
Is the led still blinking?
I had a similar problem. After two or three days the board stopped to work and start a loop of continuous reboot.
Reset or disconnect the power don’t works and nothing happen since I reset the wifi router.
Also, after router reset, the board take some hours before start working. I fight with this problem 6 month.
I tried with a couple of boards and I had the same problem so, since is a critical project,I had to change project architecture using one Esp32 and one arduino mega pro serial connected.
I think without having more information like
- how many LEDs
- how connections are made
- how power was supplied
etc.
no help can be given.
