Hello, i have the same kind of problem. I tried this :
This is a library for the BMP280 humidity, temperature & pressure sensor
Designed specifically to work with the Adafruit BMP280 Breakout
----> http://www.adafruit.com/products/2651
These sensors use I2C or SPI to communicate, 2 or 4 pins are required
to interface.
Adafruit invests time and resources providing this open source code,
please support Adafruit andopen-source hardware by purchasing products
from Adafruit!
Written by Limor Fried & Kevin Townsend for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#include āSSD1306Wire.hā
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
SSD1306Wire display(0x3c, SDA_OLED, SCL_OLED);
TwoWire I2Ctwo = TwoWire(1);
Adafruit_BMP280 bmp(&I2Ctwo); // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
I2Ctwo.begin(SDA, SCL);
while ( !Serial ) delay(100); // wait for native usb
Serial.println(F(āBMP280 testā));
unsigned status;
status = bmp.begin(BMP280_ADDRESS_ALT, BMP280_CHIPID);
//status = bmp.begin();
if (!status) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring or "
                  "try a different address!"));
Serial.print("SensorID was: 0x"); Serial.println(bmp.sensorID(),16);
Serial.print("        ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
Serial.print("   ID of 0x56-0x58 represents a BMP 280,\n");
Serial.print("        ID of 0x60 represents a BME 280.\n");
Serial.print("        ID of 0x61 represents a BME 680.\n");
while (1) delay(10);
/* Default settings from datasheet. */
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
              Adafruit_BMP280::SAMPLING_X2,     /* Temp. oversampling */
              Adafruit_BMP280::SAMPLING_X16,    /* Pressure oversampling */
              Adafruit_BMP280::FILTER_X16,      /* Filtering. */
              Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
display.drawString(0, 10, "Left aligned (0,10)");
Serial.print(F("Temperature = "));
Serial.print(bmp.readTemperature());
Serial.println(" *C");
Serial.print(F("Pressure = "));
Serial.print(bmp.readPressure()/100);
Serial.println(" hPa");
Serial.print(F("Approx altitude = "));
Serial.print(bmp.readAltitude(1013.25)); /* Adjusted to local forecast! */
Serial.println(" m");
Serial.println();
delay(2000);
It compiles but when i try to upload it i have a kernel panic.
Any idea ?
