SHT20 Strange behavior
Testing SHT20 sensor.
I run test with arduino mega 2560, the measurements are ok.
Currently in my room there is 17.32 degrees.
When I connect to cubecell board start reading 27.26 and after 2 minutes read 31.16.
always increasing.
Also if I only want to read temperature (I comment humidity) I get the error value for temperature -273.00.
This test pass on mega2560.
I attach proof screenshots and code.
  • ReadSHT2x
  • An example sketch that reads the sensor and prints the
  • relative humidity to the PC’s serial port
#include <Wire.h>
#include <SHT2x.h>
void setup()
pinMode(Vext, OUTPUT);
void loop()
digitalWrite(Vext, LOW);
delay(50);
Wire.begin();
// Serial.print("Humidity(%RH): “);
// Serial.print(SHT2x.GetHumidity());
Serial.print(” Temperature1©: ");
Serial.println(SHT2x.GetTemperature());
Wire.end();
digitalWrite(Vext, HIGH);
delay(3000);
Which SHT library do you use?
@wasn hi, I use the embedded on framework (SHT2X) and also try the original Sodaq_SHT2x.
I try with include example:
https://github.com/HelTecAutomation/ASR650x-Arduino/blob/master/libraries/Sensor_ThirdParty/examples/SHT2x/ReadSHT2x/ReadSHT2x.ino
Hello again. Any update here ?
had no time to investigate.
but why not read both values and use only the temperature.
from the power consumption point it should not take much more.
@wasn hi yes I will do that, it’s only to show there is a strange behavior when I use cubecell.
With arruino I have no issues like I expose in this post.
I can’t use the sensor because the temperature value is fake.
I want to add:
I run test with this library: https://github.com/u-fire/uFire_SHT20
Now I can read SHT20 normally if I use VDD direct. If I use VEXT read sensor the first time after reset but after cut power and sleep when come to weakup again I cant read device.
(I am power again the device in the code of course)
the issue only is present when I power the SHT20 with VEXT after first sleep. If I power with constant VDD voltage the sensor are read fine
SOLVED.
I solve the issue https://github.com/u-fire/uFire_SHT20
Remove from setup()
digitalWrite(Vext,LOW);
Wire.begin();
sht20.begin();
prepareTxFrame(){
Wire.begin();
sht20.begin();
float temperature = (float)(sht20.temperature());
float humidity = (float)(sht20.humidity());
Wire.end();
digitalWrite(Vext,HIGH);
vext activation should not be done in the setup.
glad you have solved the problem
Check this for my working sketch: Wrong temperature measurement with your demo
