hehe, Funny you should say that. I have been looking at the same thing but sparkfun disscontinued it.
Hmm, even the Scope is reading lowe levels than i would have expected.
Using a 0.1 Ohm
Sleep mode is showing 0.058mv
Reading the sensor is 0.132mv
LoRa transmission is only 1.78mv
I do have the gateway sitting nearby in the same room and stuck a 30dBi attenuator on the antenna but that should not make too much of a diference.
Checking the battery voltage is also interesting. Battery was charged to 4.017V. over the last 12 hrs its dropped to 4.006V on a 900mah battery.
It would be so nice to have a device that you could just plug in, dial up your battery size and voltage then let it run and estimate the runtime of the system.
