So far, yes, it looks like it.
Activity over last 18hrs of one of two CubeCell nodes running a RadioLib LoRaWAN App.
Both nodes uplink ambient temp. and battery voltage every 15 minutes.
TTS dashboard:
Last activity7 minutes ago
86 up / 7 (Nwk) down
(Nwk = frame count value)
Chunk of terminal output by CubeCell node:
Just showing the part with last two downlinks received. The other 6 ones were also received.
18:16:51.380441 Sending uplink
18:16:56.513048 transceive - RadioLib state: 1
18:16:56.513245 Received a downlink
18:16:56.518859 <MAC commands only>
18:16:56.518977 [LoRaWAN] RSSI: -60.00 dBm
18:16:56.519017 [LoRaWAN] SNR: 9.00 dB
18:16:56.523974 [LoRaWAN] Event information:
18:16:56.524092 [LoRaWAN] Confirmed: 0
18:16:56.529854 [LoRaWAN] Confirming: 0
18:16:56.529960 [LoRaWAN] Datarate: 5
18:16:56.534810 [LoRaWAN] Frequency: 867.300 MHz
18:16:56.534885 [LoRaWAN] Frame count: 6
18:16:56.534921 [LoRaWAN] Port: 0
18:16:56.538761 [LoRaWAN] Time-on-air: 51 ms
18:16:56.538831 [LoRaWAN] Rx window: 1
18:31:51.431573 temp. 19.55°C, DevEUI=0x002722450c3a7530&packet=BscJfQ==
18:31:51.431747 Sending uplink
18:31:56.566627 transceive - RadioLib state: 1
18:31:56.566826 Received a downlink
18:31:56.572442 <MAC commands only>
18:31:56.572554 [LoRaWAN] RSSI: -59.00 dBm
18:31:56.572592 [LoRaWAN] SNR: 9.25 dB
18:31:56.578434 [LoRaWAN] Event information:
18:31:56.578523 [LoRaWAN] Confirmed: 0
18:31:56.583462 [LoRaWAN] Confirming: 0
18:31:56.583569 [LoRaWAN] Datarate: 5
18:31:56.589409 [LoRaWAN] Frequency: 867.900 MHz
18:31:56.589504 [LoRaWAN] Frame count: 7
18:31:56.589544 [LoRaWAN] Port: 0
18:31:56.593411 [LoRaWAN] Time-on-air: 51 ms
18:31:56.593474 [LoRaWAN] Rx window: 1
18:46:51.483312 temp. 19.51°C, DevEUI=0x002722450c3a7530&packet=BsEJfQ==
18:46:51.483487 Sending uplink
