[SOLVED]CubeCell – Dev-Board Simple Receive Example
Im searching 2 example sketches. One sketch for sending sensor data over lora and then a receiver sketch to receive the sensor data over lora. The sensor is the bme280. I found a sketch for sending, but not for receiving. Thank You in Advance
Can you post your code for a look?
I got no code because i dont know how to use this library to write a receive script. The sender script is in the examples of the board.
If you need to use the standard loraWAN protocol, you need to purchase a gateway.
This example include receiver example: https://github.com/HelTecAutomation/ASR650x-Arduino/blob/master/libraries/LoRa/examples/LoRaBasic/pingpong/pingpong.ino
Anyway, we will update another independent receiving example later.
I just want to send data from a module to a other because there is no gateway near by.
When will you upload a independent receiving example? Thanks and have a nice day
Sorry I didn’t understand you correctly at the beginning.
/* Heltec Automation Ping Pong communication test example
#include “LoRaWan_APP.h”
#include “Arduino.h”
  • set LoraWan_RGB to 1,the RGB active in loraWan
  • RGB red means sending;
  • RGB green means received done;
    #ifndef LoraWan_RGB
    #define LoraWan_RGB 0
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
int16_t txNumber;
int16_t rssi,rxSize;
boardInitMcu( );
txNumber=0;
rssi=0;
Radio.Init( &RadioEvents );
turnOnRGB(COLOR_SEND,0); //change rgb color
Serial.println(“into RX mode”);
Radio.Rx( 0 );
delay(500);
Radio.IrqProcess( );
rssi=rssi;
rxSize=size;
rxpacket[size]=’\0’;
turnOnRGB(COLOR_RECEIVED,0);
Radio.Sleep( );
Serial.printf("\r\nreceived packet “%s” with rssi %d , length %d\r\n",rxpacket,rssi,rxSize);
Thx a lot. Do you also got a send script with the bme 280 sensor ? Tried today to add it so the packet and send it but it was not working
I’m so sorry.I don’t have BMP280 , but you can reference this code.
And add the read data to the position in the picture, pay attention to the data type.
Do you know the datatype for example for float tried it but there was no success
    #ifndef LoraWan_RGB
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
double txNumber;
void DoubleToString( char *str, double double_num,unsigned int len);
boardInitMcu( );
txNumber=0;
rssi=0;
txNumber += 0.01;
sprintf(txpacket,"%s",“Hello world number”); //start a package
// sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
DoubleToString(txpacket,txNumber,3);	   //add to the end of package
  • @brief Double To String
  • @param str: Array or pointer for storing strings
  • @param double_num: Number to be converted
  • @param len: Fractional length to keep
  • @retval None
    void DoubleToString( char *str, double double_num,unsigned int len) {
    double fractpart, intpart;
    fractpart = modf(double_num, &intpart);
    fractpart = fractpart * (pow(10,len));
    sprintf(str + strlen(str),"%d", (int)(intpart)); //Integer part
    sprintf(str + strlen(str), “.%d”, (int)(fractpart)); //Decimal part
You can try this code.
Thanks a lot for the help :+1:
i got a problem, it sends two times the right data and then stops and does nothing. It does that when i try to send sensor data, with the 0.01 it works
Function:
Send data from a CubeCell device over hardware
this project also realess in GitHub:
#include <LoRaWan_APP.h>
#include <Arduino.h>
#include "Seeed_BME280.h"
#include <Wire.h>
BME280 bme280;
#ifndef LoraWan_RGB
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 9 // [SF7…SF12]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
double txNumber;
boardInitMcu( );
txNumber=0;
rssi=0;
 pinMode(Vext, OUTPUT);
  digitalWrite(Vext, LOW);
  delay(500);
  if(!bme280.init()){
    Serial.println("Device error!");
  //float temp = bme280.getTemperature();
txNumber = 0.01;
sprintf(txpacket,"%s","Hello world number"); //start a package
DoubleToString(txpacket,txNumber,2);     //add to the end of package
turnOffRGB();
@retval None
sprintf(str + strlen(str), ".%d", (int)(fractpart)); //Decimal part
Recommend do basic node-to-node communication test first. that will help you verify if there have any hardware problem.
Then add your function step by step.
