Cubecell Board AB01 TTN v3 +EU868 not working with ABP or OTAA
Just for update. I flashed a firmware using WASN configurator app with same appKey etc, and it’s working
In gateway log i correctly see the uplink from cubecell.
I think that it’s something about arduino code, do you have any idea?
maybe @wasn could help us
someone have updates?
It’s not nice to have spent money on something that doesn’t work.
From your gateway log, I don’t see the gateway’s downlink. Please confirm whether you have created the corresponding node in the server.
the log that you see in my latest post is the one done with WASN app and firmware and it’s working correctly.
What code did you use when using ArduinoIDE?
this one
I only chenged keys
You can try other LoRaWAN codes, such as this:
I use this code and it works fine.
I pasted code that you linked, i don’t know why, but it’s not working… i’m using this configuration:
  • region 868
  • class A
  • devuei custom
  • netmode otaa
  • ADR on
  • uplinkmode confirmed
  • net reservation off
  • at support off
could you please share your configuration? even from TTN end device and gateway
thanks
My configuration is like this
Can you share your serial port information?
AT Rev 1.3
+AutoLPM=1
+LORAWAN=1
+KeepNet=0
+OTAA=1
+Class=A
+ADR=1
+IsTxConfirmed=1
+AppPort=2
+DutyCycle=15000
+ConfirmedNbTrials=4
+ChMask=0000000000000000000000FF
+DevEui=70B3D57ED0046053(For OTAA Mode)
+AppEui=000000000000A0B3(For OTAA Mode)
+AppKey=B9CC3F26BBC30178567188233A7B55EA(For OTAA Mode)
+NwkSKey=15B1D0EFA463DFBE3D11181E1EC7DA85(For ABP Mode)
+AppSKey=D72C78758CDCCABF55EE4A778D16EF67(For ABP Mode)
+DevAddr=007E6AE1(For ABP Mode)
LoRaWAN EU868 Class A start!
joining...TX on freq 868100000 Hz at DR 5
Event : Tx Done
RX on freq 868100000 Hz at DR 5
Event : Rx Timeout
RX on freq 869525000 Hz at DR 0
Event : Rx Timeout
TX on freq 868500000 Hz at DR 5
Event : Tx Done
RX on freq 868500000 Hz at DR 5
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
Event : Rx Timeout
Event : Rx Timeout
Event : Tx Done
@shaffer any news? could you please share TTN configurations?
This is my configuration in TTN.
tried with same configurations, but nothing, it’s not working
How can i ask for a refund?
If you want a refund, you can contact your seller. Or you give me your email, I will give you a firmware that I can communicate normally, and confirm whether there is a problem with your development environment.
