I need to use the onboard ADC to read an external voltage while I’m having Vext=ON all the time (I’m powering up the external sensor)
AFAIK from the documentation when Vext is ON (GPIO06) the ADC will always read the battery level.
How can I modify the board and make the ADC completely “independent”??
looking to a previous answer it seems to me that if I remove BR1 then the ADC pin on the AB01 is completely free and will always measure whatever voltage I place on the pin, is this correct?
see the last answer on a previous post for BR1 location:
